Looking for any advice… Just finished tiling my kitchen backsplash. (Have not grouted yet).
I really took my time and thought I had done a lot of research. However, when cleaning joints, a tile popped loosened. Then two more. After much frustration, I’m trying to understand what went wrong and the best resolution, moving forward. The adhesive I used is Mapei type 1 mastic. The tiles are 3”x 12” ceramic. I used a ¼” notch trowel and moved the tiles perpendicular to the grooves to set each tile. Often in forums this type of failure is attributed to the adhesive skinning over before a section is done. However, I did this in several sections and no section took over 15 minutes. I waited 48 hours to clean up tiles/ remove spacers. One thing that concerns me is: I tiled over primed drywall (it’s not a wet area), but it was primed over a year ago. Could the primer have broken down? I’m attaching photos of the failed tiles, but it doesn’t seem like the adhesive is bonded to the tile and not the wall or the wall and not the tile. It’s more like the adhesive is still somewhat soft between the two surfaces even after two days. Is it just fragile for an extended time until it totally cures?
Now moving forward… I could replace the three tiles, grout it and look at it everyday, wondering when it’s going to fall of the wall and break my cooktop… I could change my technique, but I’m not sure what to do differently. If the wall surface is the issue, I could screw a thin hardibacker to the wall and tile over it (if I did that, could I use a thin sheet and screw it over the drywall (into the studs) or should I remove drywall? ( the receptacles are adjustable boxes so that’s not an issue).
I’m willing to take the time to do it right, but because I’m not quite sure why it failed, any or all advice is welcomed.
Thank you
Thank you
