Would appreciate feedback on my plan of attack for the situation described below.
I'm fixing drywall on an exterior wall due to a long-term moisture issue caused by poor ventilation due to packing the closet too full.
It's occurred about 4-5 inches each side of a blocked up mailbox chute. The moisture issue occurred over many years, so it's a long-term moisture issue. Some signs of mold.
The relative is moving so the problem caused by packing THIS closet too full will be addressed. The mail chute was closed up from the outside when the house was bought. That probably wasn't done really well and I suspect the moisture issue occurs mostly in winters (house is in MN), although having proper ventilation might have reduced or avoided the problem. Relative is moving so fixing the mail chute properly isn't going to happen.
I'm trying to address the problem with the drywall.
What I've done:
There were some signs of mold so I first washed with undiluted household (5%) vinegar.
I could tell the paper of the drywall had separated in places from the core of the drywall (the gypsum, or whatever it is) as it was loose.
I've removed all the paper that's separated from the core of the drywall. Now all the edges around where I've removed the paper are firmly attached.
I had Zinsser Cover Stain on hand so I put a coat of that on about 4 hours ago
Now, is the following process the best next things to do?
I was also going to put a coat of Zinsser BIN on top of the Cover Stain. I know it's probably overkill, but from what I've read, it probably won't hurt anything? I assume it's fine to put a coat of BIN on the CoverStain after 6-7 hours? Going to skip the BIN. Got confused by the difference between the BIN Advanced (synthetic shellac) vs. just BIN. Any opinions (for future reference) as to whether one of these is better?
Then I'm going to put a thin layer of joint compound on top of the BIN. I have 20 min Easy Sand powdered joint compound.
I haven't done a lot of mudding but I think I can get the 20 min on and smoothed ok before it hardens. Might end up doing a 2nd coat on top of the first if my first attempt isn't too smooth.
Then I'll prime the surface with Zinsser 123, and then paint with SW Duration.
Thanks in advance.
What I've done:
Thanks in advance.
