Trouble Drilling Into Studs
1 reading
27K views 7 replies 7 participants last post by  mikegp
Hello All,
It's my first time here, so hopefully I'm putting this question in the right place!
In short, I'm having trouble drilling into studs. My girlfriend just moved into a new apartment in a high rise building and I was mounting her TV on her wall. I used a stud finder to locate a stud and an 18v cordless drill to drill into it. I was using a drill bit slightly smaller than the mounting screws to pre-drill a hole, but once I got through the drywall, the drill bit wouldn't go any further. I drilled in 2 spots about 12 inches apart and I had the same problem. Has anyone here faced the same problem and is there an easy way to fix it?
#6 ·
The thought occurred to me that it might be metal studs - I'm going to check with the building management to see if this is true. If they are metal studs, any suggestions on how I might attach a TV mount to the wall?
As for the wall itself - no, it's not adjacent to the bathroom or the kitchen. It's a bedroom wall that is adjacent to the living room, so it seems unlikely that there are drain pipes passing through there.
